6 Comments
    Please post up your topic's content.
    1. Hello all, I would like to share this question with you :
      I use javascript to control the data in forms. But I have read we can develop a specific validator in a java plug-in (interesting, cause you develop it once, and use it directly in the form designer).
      To your opinion, is javascript a good solution to control the data (security pb) ?  Do you have a tuto to learn how to develop a plugin ?
      Thank you, Pierre
      1. You need a Form Validator Plugin plugin for this case.
        For example, please see the coding for DefaultValidator at https://github.com/jogetworkflow/jw-community/blob/3.1-SNAPSHOT/wflow-core/src/main/java/org/joget/apps/form/lib/DefaultValidator.java
        Javascript is only good for client-side validation and not at server-side.
  2. Thank you Bastiana for your answer
    To take in account this java coding, I suppose I have to open the project in an IDE (Eclipse or other), do my java coding, rebuild the project, and deploy it as a .war in tomcat (or something like that) ?
    Is there a tuto to to set-up this development environment ? I mean, starting from the first step : retreive the source project from SVN, and build...
    Thanks again
      Please see Building from Source. You may also try to do it by following Joget's tutorial video.
      Good luck.
