Hi Seth,
Thanks for identifying and reporting the issue. It's indeed a bug where the assignment hash variable displays the wrong assignment in subforms when there are several simultaneous running activities. This should be fixed for the next release.
Best Regards
Julian
I discovered what appears to be a bug with the Bean Shell Form Binder in a subform. To make a long story short, the hash variables for activityId, activityName, and activityDefId contain the wrong values when access from the Load Binder of a Section in a Subform.
Scenario:
Example: Sample app that I created to demonstrate the problem.![](/community/download/attachments/29822317/image2017-11-27%2022%3A2%3A8.png?version=1&modificationDate=1511838044000&api=v2)
Activity 1, 2, and 3 are triggered when the process starts
Activities 1 and 2 are mapped to a form which has a subform . The subform contains a Bean Shell Binder as the Load Binder on the first Section and displays the values of the activityId, activityName, and activityDefId hash variables in a text field. Notice in the following example, that when I click on Activity 1, the header correctly indicates Activity 1, but the subform reports that the hash variables point to Activity 2.
Activity 3 has been mapped directly to the form that has the Load Binder. In other words, there's no subform at play. When I open Activity 3, the form correctly reports Activity 3 in both the header and hash variables.
Of course this is just a sample application to demonstrate the problem. I encountered it while developing a more complicated application in which I need to be able to detect the current activity from within the subform Bean Shell. Am I doing something wrong or is this a bug?
APP_demoHashVarBug-1-20171127142702.jwa
I've attached a sample application that demonstrates this problem.
