Joget DX Available for Download
same approver name in level 1, 2, 4. when click "Approve" button once level 1,2,4 should get approved. then the form should go back to Level 3 to other approver for approval. is this possible?
      From what i understand, you are asking that if there are 4 swim-lanes/levels like
      LEVEL 1 (Approver: Meethi)
      LEVEL 2 (Approver: XYZ)
      LEVEL 3 (Approver: Meethi)
      LEVEL 4 (Approver: Meethi)
      if the request starts from level 1 for example, and the user(Meethi) click Approve so the request should go to level 3 only and after that it should finish. is that what you are asking?
      If that's the case then i suppose that in your process flow diagram, after the submission of each activity, you will have to put a tool and the tool will point to a route. In that tool you will have to write a bean shell to check if there is more levels left with the same approver name and then set a workflow variable accordingly for the route to map Also maintain a variable where you will put all the levels that are approved already and then once that variable has all levels, end the process.
      EXAMPLE:
        You can map each level to the same or different approver ( Map Participants to Users ). By "level" I mean the participant swim-lane. Each participant swim-lane can be assigned to any user or group or via a workflow variable that contains the username of the activity approver.
