Hi. I want to know how to add information for each container. For example if the user select 3 total container, then they will have to enter 3x container numbers. Cannot add more than the selected value for total container.
      Hi, I believe you can use custom JavaScript placed within a Custom HTML to perform your desired custom logic. Alternatively, it might be easier to make use of some other elements like a Grid with minimum/maximum rows configured.
