Hi. I want to ask if there are any side effects if I change the Directory Manger Settings from LDAP Directory Manger to Security Enhanced Directory Manager.
      No side effect, if in Security Enhanced Directory Manager (SEDM), you also configure the External Directory Manager to LDAP.
      Backup your Joget DB before enabling SEDM. Once enabled, users' password would be stored using a new encryption method. Disabling the plugin would cause all the users not to be able to login anymore as the default encryption method is effectively changed. If you decide to stop using the plugin, you will need to replace all the affected users' password in dir_user table with a new password based on md5 hash. Security Enhanced Directory Manager
