http://jsfiddle.net/kjy112/kchRh/
i want something like link above but text field display value from database. When click drop down value from database show in text field based on drop down value. is it possible in joget?
You can try using the AJAX Subform. You can also use your custom JavaScript in the form in a Custom HTML element.
Hi Listenwell
The Joget Workflow Knowledge Base has a lot of information to assist you, including SelectBox.
The Joget Apps Marketplace has example apps using SelectBox.
