I have a form which shows request details to the approver so he can approve/reject the request. Now, i want to add a text box for adding multiple email addresses to the approver would like share this notification.
How can i do that?
Thank you in advance
Kamran
  1. Kamran Raza
    Thank you for your swift response.
    I am using community edition so Multi select box is not availble.
    but If i put this in Hash Varible then How to add multiple email address. Does ';' work as seperator b/w two email addresses
    You can try making use of the Multi Select Box, in conjunction with the User Options Binder to retrieve the user's email addresses.
      Hi Kamran,
      put "," as your seperator
        I know how to use hash variables for an email address I may have entered into a form.
        But, if I selected a User (or Users) from a Select Box using a User Options Binder how could I retrieve the email address(es) associated with the selected User(s) using hash variables?
          or you can put the Hash Variable to the email tool.
