I want to make the sections expandable and collapsible; I have a lot of section in my form which increases the form size; I want a way to make the the section expand and Collapse on Expand on the basis a click.
Is their any easy way of doing it.
      Although you can try Show and Hide Form Sections with different field types, you can always write a custom JS to control section visibility if you want more control (like creating a button on each section to expand/collapse something similar to the Collapsible? property of AJAX Subform).
      Moreover, there's this feature called a Multi Paged Form which I like a lot in these scenarios as it loads multiple forms in different tabs making the screen size smaller.
      Hope this helps.
      Thanks!
        You will probably need some scripting to make them toggle but from markertplace, you can try out the alternatives- section wizard and tab plugins
        https://marketplace.joget.org/jw/web/userview/mp/mpp/_/vad?id=section_tab_plugin-v1
        https://marketplace.joget.org/jw/web/userview/mp/mpp/_/vad?id=section_wizard_plugin-v1
        Good luck!
