continue to question this how i can get parentid / value from selectbox to the child selectbox ?
so i have 3 select box,
select1 with id (kode1)
select2 with id (kode2)
select3
on select 3 i have query like this
select value,label,kode1,kode2 from table
so the select 3 will show value based on  group with select 1 and select 2
      Only the third column with act as grouping column so to allow grouping on multiple fields, I think you need to pass all the columns concatenated either comma separated or semicolon separated as the third column in the query.
      I know it works with the form binder where you can select multiple columns in the grouping field. But i haven't tried it with SQL
