3
We have an issue with process/start/(*:processDefId) web API endpoint. The endpoint requires processDefId. processDefId includes process version -- for example, expense-claim#1#process-name. Process version is incremented with every deploy.
We have a couple of systems that make use of that endpoint, and I need a proper way to update process design without incrementing its version.
Any thoughts?
      3
      Hi Eric,
      You can actually use the keyword "latest" to replace the numeric value for process version. This will automatically obtain the latest published process version.
      curl --request POST --url 'http://localhost:8080/jw/web/json/workflow/process/start/expenseclaim:latest:process1?j_username=cat&j_password=password'
      Cheers
      Hugo
      1. Eric
        Hi Hugo, That’s amazing - I should have just tried it I guess. Is it part of the knowledge base? Might be good to add in the docs if it’s not already there. Cheers, Eric
      Hi Mustapha,
      Please see Version Control#UpdatingProcessVersion. Process version will change on every process design update.
      Cheers
      Hugo
        I came across the same issue but wasn’t able to find a solution other than a workaround to determine the defid. Would be great if the url had „latest“ instead of a number as an option.
