what is the purpose for using workflow variable?
      Workflow variables (WV) are used to store values from the start to the end of a process. One of the many uses of workflow variables values is for conditional routing in a process flow. If WV value equals approved, go to this activity, else to a second activity, etc.
      Read more in Workflow Variables and Process Routes .
