Hi!
I would like to start a process from Datalist Hyperlink Action as described in this tutorial :
Start Process from Datalist Hyperlink Action
But I want that the Run process form be full populated with the values of the corresponding row data ( in the datalist).
It's very hard to mention all the fields in the Parameters keys section  of Hyperlink Properties
Any help please.
      Hi, you can try Pre-populate Form Fields with Data from External Source to see if it helps.
